Sparfuchs
- Joined
- Nov 22, 2020
- Messages
- 305
Hello EV friends,
i finished my e bike build and now i'm ready to go.. but...
i'm totally overtaxed with all the options of my unlocked Sabvoton SVMC 72150 software.
Is there something like a recommended set up for my MXUS 3K Turbo ?
Or does the controller adjust or change the settings by its self when it recognizes the motor and the battery (at least the basics) ?
If i have to do it by myself - what are the first or the most important settings i should adjust so i can use it safely ?
The battery pack is a 20s9p pack with Samsung 35E cells and a 50A BMS. According to the aliexpress seller it has this data:
Max Continuous Discharge Current:50A
Peak Discharge Current:150A (i was told at endless sphere that can't be right/realistic ?)
Discharge Cut-off Voltage:60+/-1 V
Cell Overdisharge protection Voltage:2.75V
Discharge Temperature Range: -20 - 60°C
The throttle i use is a standard universal throttle from aliexpress with a voltmeter display and a keyswitch. (DC: 1V - 4,2V)
Thanks a lot for your help.
Best regards
Sparfuchs
Best regards
Sparfuchs
