Sparfuchs
- Joined
- Nov 22, 2020
- Messages
- 305
Hello EV friends,
I built a e bike with a mxus 3k turbo, a (unlocked) sabvoton svmc 72150, a cycle analyst v3 and a 19s4p Samsung 40T/ 300A ant bms battery.
My plan was to get the mxus with ferrofluid and heatsinks to the max of its temperature but I'm not able to get more than 60 dc amps out of the sabvoton. The ca v3 is for now just a measuring instrument because I connected the throttle directly to the sabvoton. I did the hall angle test and it works "fine" but I just can't get more than 60 dc amps/about 5 kw/with full throttle step uphill and max 50 kph (flux weakening disabled) with a 24 inch tire.
As I "could" use up to 200 dc amps I just don't know why I can't ! I did the 36 combination test with manually set 120 and 245 hall angle but the results were best with the hall angle test (295 angle/unload 0,2 kw/68 kph...more details to the hall angle stuff in my last post).
I can't find any problem with my sabvoton settings (screenshot below) and I also checked the settings of my bms (screenshot below) and the real time current in the app and it was the same as on the ca v3.
Does anyone know what to do or what else I could try try to get the max out of my setup ??
Edit: and of course the three speed switch is permanent on high speed
Thanks for your help
