safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
The rounded tire will tend to let go with a feeling of "lightness" as it happens. A pointy tire tends to feel solid as a rock until it let's go to zero and then will reconnect so powerfully that the recoil is scary. (my too pointy rear rear tire is producing frame frex at high enough speeds as it grips and then let's go over the bumps) Tires that have lips/edges to them start to feel a little light but if they let go a little they then recapture traction just as gradually as they lost it.johnrobholmes said:Is it more important on the front tire? I could see a totally round profile on the back being more rideable, depending on the steering tube angle.
My bike is completely wrong... my front tire is more flat and with a lip and my rear tire is pointy...
Ideally this would be the other way around with a front that is slightly more pointy than the rear. You want a wide and flat rear tire with a lip so that you can get the rear to drift out a little. I'm starting to use some rear brake now as I go into the turn because if you are careful with it you can get the rear end to loosen up a little and that seems to help the front end feel more firm. (it transfers weight forward) I can't swap the tires because I need the rear tire for it's stronger sidewall support because of the weight of the bike.
"Argh... this bike I have and even the one's I'm building are so technically crude and primitive compared to what I have in mind."
...but my fabricating abilities are not that great and the parts I have to choose from are not great either. (I'm constantly searching for parts) We live in primitive times when it comes to a genre that "doesn't exist" yet. (this is more or less by definition... how can I expect parts to exist for an idea that has never been realized)
But I don't have the resources to do it all... so I do the best I can and if I keep at it long enough I'll at least get closer to the ideal.
Patience, patience, patience... :wink:
