dirty_d
Uhmm....got car headlights?
but is that as fun as sticking coils of bare wire in water and running high power through it?
xyster said:Uhmm....got car headlights?
dirty_d said:but is that as fun as sticking coils of bare wire in water and running high power through it?
CGameProgrammer said:You're never supposed to use "pure solder" joints if it can be avoided; you should always ensure a strong mechanical connection independent of the solder. That's hard to do with Deans connectors which is one reason not to use them. Andersons can be crimped on wire easily, and the large size (50+ amp) holds together very strongly so they won't decouple either.
safe said:My understanding (I haven't used the Andersons) is that they don't have the same wear charactoristics and also lack the positive/negative configuration that prevents getting things connected wrong. That was one of my main worries, that I'd accidentally connect the wires wrong and create a short. Anderson Powerpoles are single connectors and not double.
Or am I wrong on that?
xyster said:Powerpoles have curved contact pins that snap into place and hold the connectors together. When two pairs are snapped together, it takes approximately three pounds of tension to pull them apart.
safe said:xyster said:Powerpoles have curved contact pins that snap into place and hold the connectors together. When two pairs are snapped together, it takes approximately three pounds of tension to pull them apart.
So what does three pounds of tension feel like?
Does that mean you have to apply a lot of pressure to get them to come apart or that they come apart pretty easily? (wait a second... don't they mean the ends snap together and not the "units" of positive and negative? This still isn't clear to me yet. What is snapping with what?)
Also, it does look like there's a color coding scheme, so you could safeguard yourself from error with color coodination.
Remember... $6 per pair of positive and negative wires... (looks like 4 pieces equivalent)
xyster said:Best prices I found for complete sets:
http://www.powerwerx.com/category.asp?CtgID=3578
and where I bought mine.
dirty_d said:are you sure you're soldering this stuff together right?
CGameProgrammer said:The only disadvantage I can think of is that the smaller ones decouple pretty easily, and so they could loosen in a high-vibration environment.
dirty_d said:...you shouldn't have to heat it up that much just enough so it melts and the solder should flow everywhere and into the cracks and look nice.
