Hi guys,
been tinking with electric bikes now for a few years.
Currently working on a battery pack and charger solution for my 500w 48v mountain bike conversion.
What I've got is 4 x 5500 RCKING 22.2v 6s lipos.
I have them rigged up in 2S2P for 11ah at 44.4v.
However at present I need to disconnect em all, remove from bike charge them 1 by one, etc etc... right pain.
So, I bought a GTpower Xdrive6 4 way charger which allows charging 4 6s packs in parallel (each at 6amps) which will allow me to recharge the whole pack quickly and safely with fully balanced charging.
However I'd like to get a bit smarter than that and avoid having to take pack to bits, etc to plug it all into charger.
So here is the plan:
- one dyecast aluminium box big enough for batteries,
- latching push switch and 2 x 24 pin PC PSU style connectors (male and female x2)
- 3 12v relays (which I'll switch on 22v) which can handle 30 amps.
I wire up each 7 pin balance lead + main power leads to female PSU connectors. 9 x4 = 36 pins in all.
I wire make connectors to my GTPower.
OK, so now the tricky bit - obviously before I actually charge I have to isolate each battery again - I can't charge then while they are still in 2S2P - so I need to break 3 connections:
- on each parallel pair, I need to break the +ve link
- i need to break the single serial link across the 2 parallel pairs.
hence - 3 relays (or one 3 pole relay- but I couldn't find one that could handle 30amps (my max load when in use), so I'm sticking with 3 30amps relays.
I control the activation of the relays with a flat mount push to latch button (cannot be pressed by accident), and use power from one of the lipo packs (22.2v) to switch them (rated at 12v but they should be fine at 24v).
So once all rigged up in the box. To charge all I need to do is either on or off bike, push charging button down, then connect charger 2 plugs to box (carefully marked A AND B so do not mix them up), and start charging.
Once all packs fully balance charged, removed cables, push button to open close relays (i.e. relays connected to close latch with no power) and away we go.
Does that sound like it'll all work fine or have I missed something terribly obvious ?
stu
stu
