Schematic for magic pie 3 kit
Stephen1
New England Region, USA
Does any body have complete magic pie 3. Schematic block wiring diagram? I am not looking for a wiring layout diagram. I am looking for an electrical diagram. From battery to controllers to the electrical components. Also need the diagram for the controller?
Looking for a complete schematic wiring diagram for magic pie 3 kit. I do not need the layout diagram. I need the electric connection electrical wiring diagram. Starting from the battery to the controllers and motor to the PAS and the electrical components throttles cruise and brakes controls
Looking for a schematic wiring diagram for the magic pie 3 kit with the internal controller. Golden only shows a layout wiring diagram. It does not show a block electrical wiring diagram for trouble shooting electrical problems? For example what is the internal wiring connections for their 4 pin for the brakes,throttle and cruise? What is the internal electrical connection for the 5 harnesses going into the 8 pin junction on this kit? Also need the internal electrical connections for the controller to the motor and hall sensors? If any body has a diagram could you email it to me at nsdcstore@gmail.com. Much appreciated thanks Stephen
Does this help?
Hi Marty. Thank you for your reply. That is a layout diagram it does not tell you the wiring inside the 8 pin or the 4 pin connectors or the connection where the 5 wire harness meets inside the junction. Or even the controller I internal fets to hall sensors thanks mark
