KozmoK
- Joined
- Nov 1, 2016
- Messages
- 18
I have a SEEV 800 fat tire scooter. Original Battery pack would die after driving a block. Opened it up, the pouches are a little swollen. The original SEEV 800 batteries are a whopping $550... if you can find a replacement (I am currently calling and emailing around)
The Battery Pack is 60V 30A Max 12ah (with a 30 amp fuse)
I thought I would be cute and buy two GreenWorks 60v 5ah and run them in parallel. I printed up two amazing slide in cases for the batterys and when I went to test it... there was too much voltage sag. I put a meter on it, and it would get up to 24.9a MAX but it just wouldn't take off my my big butt on it. I am now down $260 for those two batterys
My fault I know. I should have done better math or asked here first!
I am wondering if I went with the Greenworks or Kolbalt 80v , I think that has max amps of 30amps - I am wondering if the controller can handled the extra 20v?
Main Technical Parameters of the Controller
1. Current limiting protection value: ≤25±1A
2. Under voltage protection value: 52±0.5V
Thanks in advance! Love this site!
Scott aka KozmoK
Scott aka KozmoK
