agniusm
Hi. Was looking for more info on segway X2 battery pack. So far i figured out that they are 73.6V, 5.3Ah per pack and uses Valence 1.4AH cell. My math shows me that there are 4 cells in parallel groups, 23 groups in series or 4P23S.
Max continuous discharge on these is 2C and cycle life at .2C at 100% DOD is something like 5000 cycles to 80% capacity and ~7200 cycles to 70% capacity. Cells are 40g each making 3.68kg per pack.
I was asked to rebuild battery packs on rented segways but somehow it does not fit in my head how 5K cycle life cell died in two years? If they would be charged 7 times a day they would be at 80% capacity after 2 years which is not possible with charging time of 10hrs. Only explanation i can think of is incorrect use. I was told that one winter they were hooked up to a charger all the time and they are charged fully when they are not used as well.
Is there some wanky electronics like on makita chargers that disables someone swapping cells in the pack? Any sources for Valence cells?
