speedmd said:
This whole topic of wave forms, pulse widths / frequencies and timing has some interesting possibilities /results. Lots to explore beyond the simple/gross efficiency question. Harmonics and how a controller best deals with them is another whole area to explore. I need to learn much much more :?
I'm not sure if bowlofsalad ever got a clear answer to his original inquiry, but in spite of the many variations here I can say a few things in regards to ebike controllers and motors encountered in practice.
1) If you have a trapezoidal drive motor controller with a relatively low eRPM motor, and the hall sensors are properly located on the stator core for neutral hall timing, then the efficiency and motor performance will be pretty much identical whether you run the controller sensored or sensorless.
2) If you have the same system in 1, except that the halls are poorly aligned in the motor so that their timing is off, then you'll get noticeable current ripple and "buzz" from the motor when you run it sensored, but sensorless it will run nice and smooth. In this case running sensorless should have marginally better performance. Probably undetectable riding the bike, but likely measurable with an accurate dyno system.
3) If you have a motor with a high eRPM's, then many models of sensorles trapezoidal controller will have some commutation lag time as a result of firmware limitations in their back-emf sensing code, and this will result in delayed commutation timing and excessive ripple current and inefficiencies. How much really depends on the particular controller and eRPM at which you run it, but I've seen some very ugly oscilloscope waveforms of ebike motors running at high speeds on sensorless controllers not really up to the task. In this situation, sensored is generally better.
HOWEVER, some digital sensored controllers also have a firmware lag time from when a hall transition happens to when they commutate the phase outputs, and some really bad ones only synchronize the change in commutation with the start of the next PWM duty cycle on the mosfets, leading to an unnaturally discretized and jittery commutation frequency even if the hall sensors themselves are perfectly timed. Meanwhile some sensorless controllers will still be spot-on in having neutral commutation timing even at high eRPMs. So with high eRPM motors the answer is very much one of "it depends" on the implementation details of the particular controller.
4) If you have a field oriented controller, then best behavior for sure is sensorless for the reasons that Lebowski said. The only time it makes sense for a FOC to base it's output on the hall signals is when the motor is at a very low speed and the controller can't reliably figure out the rotor position.
