I just received my CA v3 and have some questions regarding programming. The controller I purchased from Lyen has a plug in for the CA but the throttle and three speed switch would need to have the plugs changed out.
DO you recommend changing those so the throttle and three speed switch run through the CA or just stay through the controller, I have the programming plug for the controller?
Also I am running a 48 V 1000 W hub with 18650 54.8 V 15 ah battery. This is on a cargo bike I use to shuttle our two kids around while I pedal assist.
I could really use some advice on setting up all the parameters to get the smoothest safest ride. Thanks .
I built the frame up with mountain bike gearing.
Thanks Donny
Thanks Donny
