Ryanisfree
10 µW
- Joined
- Oct 25, 2017
- Messages
- 6
I was hoping for some advice from you educated peeps!
I have set up my system and got it working with throttle only. I have installed a Thun bb torque sensing and doesn't seem to work. I have enabled the sensor in cycle analyst but still no function. It is set to 3 times input. I can't make sense of the other settings. Any advice? I am worried I damaged the cables upon installation as it was a bit of a jiggle putting it all together. I sincerely hope this is not the case as the bracket was very expensive.
Secondly. I have a 52v 29ah battery driving 2 X 250w geared hub motors. I have set max power to 22amp (thanks ebike school.com) and 15 battery cells seems to give me 52v setting. Other than that I can't make any sense of the rest of the set up ie. Throttle voltage etc. Can anyone walk me through the setup to optimise my machine?
I will post some pics fairly soon of my set up. I've a set up a wind screen to block cold air blowing on to me. Others may find it interesting or useful
Many thanks
Many thanks
