Sevcon Gen4 Problem - any tips?
Germany
Hello,
I have a problem with a Sevcon Gen4 controller, all is wired and then I was turning the inigtion on the contactor closed and I could go with the Sevcon Calibrator into the settings of the controller. I checked the inputs, everything was fine, only error was the motor encoder. Than I did some changes, stored and went in operation mode. Than the led starts to flash once repeating and i could not go back in the settings. The calibrator shows the Gen4 as slave after conecting but than I try to go into the settings or test, it says no device and I should check the CANbus.
Has anyone had the same problem and/or a solution?
I only have the calibrator for the Gen4, I also have a Millipak with PowerPak software and interface, but this seams not to be compatible :cry:
Thanks in advance for any help!
Sebastian
Hello again,
maybe someone knows which Can intefaces are suported by the controller and support CANopen?
Regards,
Sebastian
Send an email to Sevcon and ask?
Since it's their product, they should be more than helpful.
I did, seams the calibrator is limited and not the way to go. I ordered an IXXAT CANopen interface and installed the DVT software. Worst case can be that something went wrong and the settings of the controller are currupt, than i need to reload the standart settings with DVT.
Anyway I cant understand why the calibrator can display the controller as a note and says no faults. But you cant go into the controller :?
Sebastian
Hi Sebastian
I've been playing with the DVT software for my motorbike, and it's working very well now. I understand the hand controller is quite limited on which parameters can be adjusted. The DVT software is pretty straightforward, once you get the hang of it. The Configuration files are in txt format, so quite easy to read and edit manually as well.
Your fault almost sounds like a baud rate problem, and it's stuck in pre-operational mode.
If I can be of any help, give me a call
Regards
Charles
Hello Charles,
thanks for your answer. Seams you are right, stuck in pre-operational and now I cant connect with the handheld. Now I am waiting for my IXXAT usbtoCAN adapter.
What motor you`re using? I have a PERM PMS 120 with sin/cosine encoder.
I have a Mars ME0907 motor with hall sensors, so I think easier to set up, but the sin/cosine are much more accurate.
I've noticed with the Gen4, it's very easy to make a slight adjustment to a parameter, and the unit will fault, and so stay in pre-op. It's not a problem if you have a backup file that you can revert back to.
Charles
The DVT software gives good fault explanations when you do a settings check, or get fault information, so hopefully, you should be able to sort it.
Hello again,
today my canOPEN device arrived, I made a cable and was happy to be able to connect with the Gen4 again.
I have 4 faults displayed in the attached image.
faults:
#0 & #1 i should use 5621h to identify the object being out of range, how is this done?
#2 check encoder wiring - this i made several times. is it possible that this accurs because on my analog inputs pin 35 is not mapped and this is the pin for my cos-input?
#3 no idea why
I hope somebody can help me. Its very hard for me as a newbe to get this managed and for me this is not very intuitive software..
Best Regards, Sebastian
I eliminated the source of the encoder fault and found that the node-id was 0, range is 1-127. This caused the internal fault. After this i have no fault in pre-operation mode. So far so good, but than i set to operation mode and recycle key, i get a HeartBeat fault from the canBus, LED flashes 12 times and you are again not able to run the motor. I get mad this time..
When you launch the DVT program can you see messages in the CAN message window?
IF you query flts what is the response?
-ryan
HI Sebastion
You probably have worked this out, but there are several useful functions in the GUI (DVT Top) Menu which is the H on the drop down list.
Get Fault information is the same as the FLTS command.The codes should link to the master list I sent you. and then in the settings command, the two functions find range error and settings check, give a load of detail.
Charles
querlenker said:
Hi Ryan,
which window do you mean? The one in the middle? If so this is mostly empty..
I am talking about the CAN window , it is 2 spaces up and on the left half of the screen from the photo you took.
Take a photo of the entire screen (or save a screen shot by pressing your Print Screen key on your keyboard then pasting in a picture editing program such as MS Paint), and I will be able to help you locate the screen, and maybe trouble shoot your situation a bit better.
-ryan
Hi,
now the controller works, it was set of problems, when I tried to change some parameters with dvt and stored them they were gone after recycle. I had to change all currupt parameters at one time in the dcf file and upload it than. After this it worked. Strange behaviour of the device.. anyway I am happy now :)
Hi guys!
I have the same motor, Heinzmann PMS120, the one from Brammo Enertia.
I bought KHB Kelly controller for it, but now I realized that motor has sin/cos encoder and controller has hall sensor input... :? :? So controller is useless...it is for sale now :D
An option is to buy Sevcon gen4 controller. But I am not sure if I can properly programm it.
Does someone has settings for Sevcon for PMS120 motor, so I can just upload them to controller?
Thanks for the answers.
Hi,
I do have settings for the motor and encoder but I think they don`t match the Brammo stock settings. The encode needs to be set up individually with every motor. There should be a script for doing it with the dvt software, but I dont own this. If you like you can have my motor settings.
Hi,
great, I appriciate your help. Motor is used in Husqvarna enduro conversion so I do not need excactly Brammo settings.
Now I am considering, buying sevcon gen4 or other motor that match with Kelly cntroller.
I am also waiting for reply from Heinzmann if there is an option to just add hall sensors to the motor.
Where did you buy your Sevcon? I am from Slovenia and really do not want to order it from USA :cry:
Hi,
where did you buy CAN interface? How difficult is to programm the controller?
Heinzmann can not provide me correct parameters for my motor, because it is special production. The only way is to buy sevcon gen4, CAN interface and spend hours trying to programm it :cry:
The worst thing is, that I need it in 10 days :? :? :evil:
Hello everyone,
I have a Govecs scooter that was working beautifully until yesterday...
yesterday i was modding some parameters (not the first time) and decided to change the encoder angle (for the 1st time) and, all of the sudden, the controller stopped working.
What I see in the DVT is similar to this: https://endless-sphere.com/forums/viewtopic.php?f=30&t=61163&p=937314#p937314
Now, I can't do anything, it seems to be stuck. The contactor doesn't power up, display doesn't work, can't enter bootloader mode...
Any ideas or commands to try?
Thanks in advance!
Hey everyone! I'm new to the forum.
I'm an Bachelor degree Electrical Engineer currently working on the master's thesis. a Sevcon gen4 has with a PM machine has been assigned to me and since those things can be tricky, I registered to help and get helped. I'm not good with forums (even though I read the rules) so if I do anything wrong, advise me. I'm quick to learn :wink: .
Should I open a new thread or post my doubts here?
I would suggest you open a new thread otherwise you are hijacking this one.
