Hello everyone, I hope Google Translate helps to translate my German into English!
So I have 2 x Sevcon controllers (from E-Max110s), both have the same software and hardware version, and yet the recuperation is different and I don't know where I can change that in the DVT.
Controller 1 has something like a recuperation braking function when you let go of the throttle grip.
Controller 2 has recuperation via the brake light switch, i.e. when you pull the brake lever the recuperation takes effect.
I want to keep controller 1 as is but change 2, where can I find the entry?
Another question would be:
The DCF file from controller 1, could I just play it in controller 2? Essentially cloning?
What does it look like if the hard version is a number older, or the software version? I have other controllers However, there are some things you just can't just get to grips with.
Greetings
Greetings
