Knuckles
20-mhz mod is easy. It took one minute. Bafang runs great at 72V and 30 amps w/ 20-mhz resontator!
Knuckles said:20-mhz mod is easy. It took one minute. Bafang runs great at 72V and 30 amps w/ 20-mhz resontator!
shinyballs said:Knuckles said:Push either type motor too hard and, bammo! … Blown hall sensors. IMO the Bafang PMGR and Grubee DD motors should never be pushed beyond 72V & 30-amps. Even if you replace the wire harness with thicker phase wires (highly recommended btw. See ... http://endless-sphere.com/forums/viewtopic.php?f=2&t=4626), 2000W into the motor is about the max you can go without overheating the motor and blowing the hall sensors.
NEVER RUN THE BAFANG ABOVE 30 AMPS!
Hey, Maybe we should commission the Bafang Company to build a 5KW PMGR that we can push to 20KW!
Is running Bafang at 72V & 30-amps continuous?
I'm really looking forward on the revised Shenzhen controller. So, Keywin is presently working on it, will they be ready next month?
Is it continuously or just for 1 minute?Knuckles said:20-mhz mod is easy. It took one minute. Bafang runs great at 72V and 30 amps w/ 20-mhz resontator!
aaannndddyyy said:After using the Ecrazymans 48volt 28amp controller with the 24 MHz 3 PIN CERAMIC RESONATOR, fitted to an Ezee sprint Brushless 350 watt motor for the last week. The throttle seems a little unstable at low revs, it stays at a stable speed for a couple of seconds then accelerates slightly for a moment then back down to the stable speed again it may be doing the same thing at higher speeds but isn’t so Noticeable, is this because of the resonator? Or perhaps a wiring problem, I have changed the throttle over with a different one with the same affect and checked the connections. By the way under no load testing this problem doesn’t show up.
72V nominal 30 amps continuous for as long as you want. But with a catch!shinyballs said:Is it continuously or just for 1 minute?
Knuckles said:72V nominal 30 amps continuous for as long as you want. But with a catch!shinyballs said:Is it continuously or just for 1 minute?
Knuckles said:The Bafang PMGR is a very powerful motor but it has nylon planetary gears.
The "catch" I speak of is that e brakes are essential for this motor to prevent some moron from braking and twisting the throttle at the same time.
So e brakes are the rule when using the Bafang PMGR (at any voltage)! Sheeeet!
K
At 72V and 30 amps the nylon gears will "shred" if you "power brake" the motor.
Yes it has a hollow shaft on one side where the wires pass thru the axle. But all my DD motors have the same wire harness arrangement also.shinyballs said:Does this motor have a hollow shaft where wires pass through it? If its does, this motor shouldn't be used for heavy loads - like in a tandem bike setup or heavy weight riders..
Keywin is sending me replacement nylon gears right now. I also asked him to ask Bafang if they make steel or alloy planetary gears.voicecoils said:Knuckles said:The Bafang PMGR is a very powerful motor but it has nylon planetary gears.
K
Thanks for your reply. Does Keywin sell nylon gear replacments?
When you say "e brake" are you talking about regen braking or having a controller cut off switch mounted to your mechanical brakes so that when you hit the mech brakes the motor cuts out?
Knuckles said:Hmmmm. Maybe time to split this topic off into a Bafang PMGR analysis thread.
Excellent idea of using "regen braking" to test if there is an internal freewheel in the hub motor.fechter said:Try shorting all the motor phase wires together and turn the wheel forward. Compare resistance to backward direction.
docnjoj said:Nah! U get old, U forget coming up to stop signs etc!! I really ought to make a cutoff switch for my brakes, but I have a trike wih both front discs energised by one brake lever. Anyone got an idea?????? Its easy to screw up!
otherDoc
docnjoj said:Thats super clever1 Dont U have a kit I can buy. Gettin all those parts is a big job for a lazy guy!
otherDoc
