Ykick
1 GW
'see it over and over - folks building (assembling) hub motor eBikes and they dunno what to do with shifters. Thumb, half or full twist throttles compete with shifter location plus all the wiring for throttle, brake, speed electrical switches can be quite a bundle to run to your controller - it's a very common problem and issue practically everyone must deal with during eBike assembly.
On the couple bikes I've assembled my solution was to simply forgo the shifters. In both of my cases 'completely removed the front de-railer and locked the rear de-railer to the smallest freewheel cog. My 26" wheel ratio gearing is now 48T/13T running 12S Lipo which happens to be all I need to help on hills and allow for some amount of leg push every once in a while.
So if you're dealing with this issue on a multi-speed bike ask yourself this: "do you really need to shift gears?" In many cases you probably won't shift much, if any, because the motor will provide more than enough thrust to make up for the lack of gearing selection and it greatly simplifies the layout on your handlebars and subsequent cable routing.
I'm not suggesting that this is the best or only way but it's worth weighing pros and cons of your situation and you may be able to save yourself a lot of headache by eliminating something that many of us won't ever use or need.
