chicken4later
- Joined
- Nov 24, 2018
- Messages
- 2
Hello all, I just picked up an IZIP e3 path plus second hand for very cheap... but the battery charger was missing. I believe the bike has been sitting for about one year with a dead battery.
the battery is model number BT-E6000, it has 40 18650 cells in 10 groups of 4 for 36v total
since the correct charger is over 100 dollars i decided to go ahead and buy a generic 36v lithium battery charger and try to make it work. When I plug the charger into the pack it wont charge the battery. The BMS is not passing the voltage from the charger to the cells. reading online I found that some BMSs wont charge the cells if they drop below a certain voltage, so i charged the cells directly for a few minutes.
The pack started off at 18.6 volts and i charged it directly for about 10 min and the voltage rose to 33.2v. Then I went back to charging from the connector on the outside of the pack and still noting. my charger is rated for 2 amps and the factory charger is 4 amps
There are also 2 small wires going to the connector on the battery pack so i am wondering if the original charger has to communicate with the BMS before allowing a charge? or are the wires only to communicate with the controller on the bike? Is my battery pack worn out from sitting too long? Any ideas on how to get this thing going would be appreciated... I want to ride my bike!
if anyone has a shimano e6000 charger i would like to know how many connectors are on the plug
