Shopping for a faster e-scooter is difficult.
marka-ee
Regular
Time for me to get a slightly faster electric scooter. I've been through quite a few of them. I've been using electric scooters for 20 years now, since the old Go motorboard was available, if any of you remember that.
Anyhow, I've been looking at these cheap Chinese ones, such as the Kurakin G2 Master for instance, which is a dual motor one, but honestly, there is almost no information about how these are built.These Chinese ones have evolved a bit so they're not quite as rough-looking as the earlier ones But still I think they're built on a principle of "It should look like a good scooter.". Doing a little digging However, and I could see that the main pivot points on suspension are el-cheapo press-in steel? bushings , Total crap. Try to get information on what battery cells they use: forget about it. So it seems that they're still basically at the point of just gathering random parts like a controller battery pack BMS and slapping it all together in an aluminum box bolting some swing arms to it and Howdy-Duty we're done! Looking at Reddit and the electric scooter forum isn't much use either. In fact, none of those people even seem to ask about what battery cells are in something, or anything deeper than looking at the outside of the scooter.-sigh-
I've been pretty happy with the Segway Ninebot Max G and G2 that I've had. They never required any maintenance and the gel that they put in the tires really does work as far as flats. I've had 4,000 kilometers of zero flats on one of them. That's pretty impressive.The Segway company looks like they actually employ some real engineers that try to engineer things a little bit better. For example, the BMS allows you to read out individual cell voltages and also lets you set the max charge percentage so you don't have to charge to the ridiculous 4.2 volts that everybody else does, which doesn't help battery life whatsoever.No respectable EV builder in the world charges their lithium ion batteries to 4.2 volts. Ideally, I would probably want to get the Segway GT3 Pro, which is a good balance of quality and speed and not too heavy. Teardown of the GT2 show that they used ball bearings or sealed bearings for the pivot points... plus one point for that.hydraulic dampers on the double wishbone front suspension plus another point for that.but it's a bit pricey so I don't think I can afford that particular unit for right now. I've been looking at the Apollo City Pro, which is a Canadian-based company, but I'm afraid of them going out of business because they're small and don't sell that many of them. Also, I saw on Reddit pictures of some person who managed to break the steering stem, probably because of a bad weld but it doesn't seem like they want to admit that they perhaps abused the scooter.
Enough ranting, but if any of you guys know of one of these low to mid-price Chinese units that actually seems to care about their product, please recommend something. I want something that doesn't look too fancy and not too big because the local authorities in my third world European country that I live in would pay attention too much if I get something fancy. Although it seems that a lot of kids here have these cheap Chinese scooters and they're racing around all over the place. At least they wear helmets it seems.
I like Apollo. I have their Apollo Pro 2019. It’s a dual motor scooter like what you are looking for. At the time, they used LG cells. My battery has MH1 cells. Yah it can do about 40MPH, but I like it at about 15MPH. I got this scooter for a great deal. I fixed my buddies other 60v scooter and he was stoked I got it back and running. He offered me this scooter for $700USD. The battery alone was (about 2 years ago) almost that much!
I have been looking at dual motor scooters before I got this one. I really like that the frame and parts are still available.
Here is my scooter. I added the light at the handlebars and got rid of the horrid slick tires, but it’s original otherwise. I'm about 170lbs and my kid is about 60lbs. We take this to school (again I have the speed limited to 15MPH) and the scooter brings us, easily, up our 12% grade hill heading home.
The reason I mention this particular scooter is because there are many clones. I’m not sure who did it first but, the Varla Eagle One and Zero 10x are the same.
I saw an old behind the scenes video at Apollo. They explain that the scooter is mass built. I know this was years ago, but the company has been around for a while now and I'm sure they will continue. I like their process (assuming it's still like in the video) for quality checks. I also like how the select their own battery. Though, maybe the OEM factory won't ship these with batteries, so maybe they have no other choice.
Given what I know about them, I'd shop there today.
I'm looking at possibly getting the Apollo City Pro 2022 version. It looks a bit different. The springs are different, but I did see a teardown video and it looks like they're using ball bearings for the main pivot points. However, I don't know what to trust anymore because most of these types of companies change parts willy nilly and they don't really need to report the change because it's not specced out in the specifications page anyway. Of course, I do assume that the scooter is mass built, otherwise it would cost two or three times as much, right? Are you insinuating that the factory that makes them in China is also just running an extra 500 or so units and slapping a different name on it and then selling it through a different channel? This isn't an unknown phenomenon in Chinese business, unfortunately. Of course, you wouldn't know what cells are inside or any other things.
Cool, looks like they use the LACROIX Stormcore esc, which is VESC compatible AFAIK.
