cornflakejoe
10 µW
- Joined
- Apr 12, 2014
- Messages
- 5
My 48V 10ah lithium battery has 2 sets of cables. One set of positive and negative that is to power the ebike motor...the other set of positive and negative is to charge the battery.
So...I was changing the charging cables to a different type of end connector...and I accidentally touched the 2 wires when doing so. I was not sure if would be hot, as I figured the charging wires might not be...but I was wrong. BAM! 48V of pissed off spark. I was lucky enough to have been using rubber isolated tools, so I was ok...but I'm not sure about the battery.
Because it was the charging cables, it would have led to the BMS I assume. I've not tried it since. I'm scared to plug it into the charger and I'm also worried what may happen when I try to use the battery to power the bike now.
I'm going to give it a try tomorrow, but I was hoping to look for some advice as to what I may have damaged. Any chance I might be ok? If by chance, would the BMS perhaps have a fuse incase of such stupidity? (I have an inline fuse on my cable that goes to the ebike motor). If not, then I'm in for some big bucks on a new BMS.
I'm sure I'm not the first one to do this...and if I am, well then I feel even stupider!
Looking for advice
Looking for advice
