Emm2849
10 µW
Hi everybody, my names is Emmanuil and I am new to this forum. I am currently upgrading a to razor pocket mod from a 24 volts to 48 volts, with a 48 volt 2000 watt motor and 48 volt 20 amp battery. The motor runs at 4200 rpm with maximum of 5200rpm. The stock pocket mod comes with a 11 tooth sprocket and 80 tooth wheel sprocket. I’m trying to figure out if I could use a 20 tooth sprocket without damaging the new motor and/or motor. I read in some other forums that it would work running it with 20/80, it would make it faster and it would also run cooler because of the reduced load on the motor . I’m new to gear ratios and do not know much about them, so please correct me if I’m wrong. Thank You!
