greasypants
- Joined
- Mar 10, 2007
- Messages
- 98
Well I finally got around to doing the controller mods I wanted. Soldered two shunt wires together to increase amperage in my 72v35a controller as well as adding extra copper to the bus bar and upgrading the incoming power lines to 8 gauge stranded copper wire . I also added 10 gauge solid copper wire to all the connections on my nimh battery packs and changed the output wire to 8 gauge. So now running 72v at somewhere between 60 and 80 amps. The problem is I do not have a milliohm meter so I don't know what the new shunt resistance is and can't program my DB2 properly. I set the shunt resistance in th BD at .7 (guessing) and max amps at 50 but I am still blowing my 60 amp fuses. Anyone have an idea what the new shunt resistance may be. I was just going to buy a pile of fuses and slowly change the shunt resistance until the fuse blows at 60 amps as displayed on the BD. Would this give me a close approximation or are the tolerance for fuses not very accurate? I just want to get it as close as possible so the rest of the DB reading are accurate.
Thanks
Greg
Thanks
Greg
