Sunder
Okay guys. At my wit's end. I've built one pack from scratch before, and repaired two packs... And I've never come across this problem.
Tried to assemble my 9S packs into 12S packs. Remove all the unnecessary bits no problem. Come to join the packs together, and I flux, I sandpaper, I file, I use a razor blade to cut a cross hatch on it, I degrease, I try to pre-melt solder onto the tabs before joining... Nothing works for one of the tabs. Solder simply balls on this tab while it sticks to pretty much every other tab.
I'm the first to admit that I'm not a pro-solderer. However, I've never come across this. I'm using a nice strong 65w iron, and it's always worked for me for every other pack.
What do people think about using silver (conductive epoxy) for intra-pack joins. Will it conduct well enough?
Thanks in advance. At this point, while I'm open to any advice, I doubt anything you could convince me about soldering will make me try it again with this tab in particular.
