Skippic
Can someone help me building a very simple BMS?
I'm looking for a balancing solution, that can be connected to a 10AH battery pack for at least 2months without discharging it completely.
If the battery is balanced with each charge, the voltage differences will be small and LVC / HVC for the whole pack (not individual cells) should be enough to protect it.
I was thinking of using a 4.1V zener diode in series with a small resistor to protect it. They would be connected to each cell. I'm not sure what the current at say 4V would be through the diode. Can anyone help me with that?
Also are there any decent 4.1V 2W zener diodes with little tolerance in breakdown voltage I could use? I was hoping to keep it simple without need for transistors...
