317537
- Joined
- Oct 19, 2008
- Messages
- 939
I tried those cheap 12v to 60v boosters off my solar system , the non-isolated type from ebay, without too much sucess, even with resistors I found it dropped from the converter output set voltage, almost to pack voltage over the resistor to get it to work, meaning 60v to 53v @ 2amps, I think about 6v i was reading , a waste of 12watts, which isnt terrible but not ideal considering I was already running over 25% losses in the converter. Comparable to a 12v to 220v AC inverter and ping battery charger losses though.
Im going to try again with a brushed controller on the output and run it under 1.8amps which is fine for over night charging off my 350ah 12v flooded lead acid..
Im not sure .1ohm is enough resistance, and like my test system you will note that when you achive the output current you need the drop occurs, you might see, more like a .5v drop @ 15A and this is 7watts per series cell, unacceptable IMO.
