Sinewave Vs. Trapezoid Controller
Duluth, MN
What is the advantage of a Sinewave controller over a Trapezoid Controller? I currently have had two bike kits from eBay. One was a 36v 500w motor kit and the other is a 48v 1000W motor kit. Both have had Trapezoid Controllers. I have heard smooth throttle response and increased efficiency are some of the advantages of a Sinewave controller. Are any of these true? And what are other advantages and disadvantages of both? I am building a new bike from scratch, not a kit, and I am wondering if I should get a Sinewave controller. For they are two to four times more expensive. Thank you.
Main difference is the Sinewave drives a motor with less noise and may be less efficient; may not always is.
Not to be confused with a Field Oriented Controller (FOC). Most FOC controllers (For DC motors) produce a Sine Wave but use a complex feedback loop to calculate waveform requirements, I'm not aware of any Asian controllers that have a true FOC sinewave.
So what is the difference in true and not true Sinewave controllers? Also, you said sinewave controllers are less efficient? I thought that they were more efficient. I guess I heard wrong.
Should depend on hardware and firmware implementations. I think is not linear to say what is best.
Best for sure is with FOC but cheap controllers as BMSBattery S series don't have hardware that can handle FOC but at least implement sinewave.
I implemented FOC with sinewave motor control for an electric unicycle: http://forum.electricunicycle.org/topic/1109-firmware/?page=41#comment-90781
I will do an OpenSource firmware for the BMSBattery S series controllers: https://endless-sphere.com/forums/viewtopic.php?f=2&t=87870
[youtube]2nDZW4-uVys[/youtube]
The main difference will be motor noise. A sinewave will be nearly silent.
The difference in efficiency is negligible for a bike motor. Both will be very high.
The big difference is trap controllers are garbage, and sinus controllers can potentially not suck if done right.
In real World terms, on low-powered systems, the biggest difference I have noticed is, the sine-wave system activated the PAS quicker when the pedaling was commenced and there is less run-on after stopping. Whether or not that is a function of the wave forms I have no idea.
In the area of sound, I have used square-wave controllers in the 15 to 20 Amp range that are as quiet as a sine-wave of equal rating.
I had a 25 Amp, 6-FET Lyen square-wave Mini Monster, which when used on a mini-motor, produced a "hammering" effect. Perhaps a sine-wave would be smoother in that kind of scenaro.
