Once again spring is getting near. And that of course means that money starts to burn a hole in my pocket and I can feel the ebike fever rising. About time to do something about it...
My current plan is to make a single stage reduction unit, sandwiched between aluminium plates, with LH drive chain to the rear wheel. Max speed of 40kph and budget of <550$ is my aim.
Here is the parts list I've been thinking.
Hobbyking.com
2x 83.64$ Turnigy 5000mAh 6S 20C Lipo http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9176
1x 17.99$ Hobbyking 6S 50W 5A Charger/Balancer http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11668
1x 36.59$ Tz85A Turnigy Brushless ESC 85A w/ 5A SBEC http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10331
1x 4.99$ Programming card for Tz85A http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10459
1x 5.99$ Turnigy Servo tester http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8296
1x 23.95$ Turnigy Watt Meter http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10080
46.67$ EMS Express 3-4 Day Shipping to Finland
219.82$
Ebay.com
1x 65.45$ Aeolian C6374 170kv motor http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180609554846
1x 34.99$ Meanwell 12VDC 12A Power Supply http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370480864002
LiveFastMotors.com
1x ~35$ 48t Rear wheel sprocket kit http://livefastmotors.com/Gas-Powered-Engine-for-Bicycle-48-Tooth-Rear-Sprocket.html
Another motor option: Turnigy SK 63-74 http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7870
Other parts I still need:
Sprockets for the motor and middle shafts. Calculating from the desired top speed and already chosen parts, the first reduction step should be about 1:3.5. 11t motor sprocket and 38t axle sprocket should be about right.
Adapter for the freewheel. I probably have to get someone to make this one for me. Hopefully it doesn't get too expensive.
Hall thumb throttle. Most likely from ebay.
Automotive fuse and a holder. 80A one to protect the ESC.
I haven't messed around with RC-stuff before, so I've got lots of questions still unanswered in my head, but here's some I'd like input on:
1. Apparently all chain drive can be noisy, that's why people are using belts. Does it make any difference if the motor sprocket would be 14t instead of 11t?
2. I know that the cheap ESC is not the best available, but is it enough if I plan only to pull about 1200W from this drive? That should still leave some room for spiking.
3. Any general comments about the selected parts? Please point things out even if they seem like no brainers.
Thanks in advance for all the replies!
Edit: Added the second motor option and removed the freewheel with wrong threads.
Hobbyking.com
219.82$
Ebay.com
LiveFastMotors.com
