kmxtornado
I'm new and fairly overwhelmed with electronics in general. I've owned a mini e-bike (see avatar) for a few years. It's powered by two 12v batteries for a total of 24v. I know the throttle has lights and is 24v max also. Not sure about the motor size. The controller's maxed at 30A. A few questions about taking care of SLA's. Mind sharing some insight on these bricks?
1. How often should I be charging them?
After every ride? And should I be charging them every 2 weeks at least (in the case that I don't ride for long periods of time? Is that even okay?)?
2. Charge it for how long?
Turn it off immediately when the green light turns on indicating full charge? Slightly longer? Keep it charged all the time?
3. Do I need to watch it while it's charging?
...or at least keep an eye on it in the same room?
4. Temperature?
I charge mine in the garage where it's slightly colder than upstairs. Is this good? Bad?
5. How often should these be recycled and replaced?
Does that depend on how much I use it? Number of cycles/charges? Or should I be looking for some signs of it deteriorating?
6. Any other recommendations?
Absolutely no-no's? Please share as much info as you can about safety of SLA's. Thanks guys!
4. Temperature?
