sharkmobil said:
50w per meter square is a bit understatement. Unless you are crossing the Bering Strait in November, you should be expecting two-to-three times more power from your solar panel(s).
I got these puppies on my boat, they seem to deliver all the 180w per panel for their 1.6m2 size.
http://www.wholesalesolar.com/products.folder/module-folder/sharp/sharp180.html
My panels are rated at 50W apiece, around 0.44m² each, with an efficiency that's typical for monocrystalline panels of around 14% - 15%. I have four of them mounted horizontally on a canopy. Max insolation at the equator at midday is maybe 1000W/m², which equates to around 150W per m² for a typical monocrystalline panel. I have 1.76m² of panels, so theory says that I should get around 1.76 x 1000 x 15% = 264W under those conditions, or around 150W/m² maximum. The very best solar panels available at the moment might get around 180W per m² under lab conditions with a full 1000W/m² of insolation.
However, the real world intervenes to make things much worse. If you're anywhere but at the equator and at midday the panels will be at an angle to the incident solar radiation, so reducing output, in proportion to the angle of the sun relative to the panel. Also, at any time except midday horizontal panels won't give their rated power even at the equator. Add in cloud cover, the odd rainy day etc and the average output really starts to drop - if anything, my estimate above was very, very optimistic for all year round power.
There's a pretty good webpage here that explains why you never get the maximum power rating published for any given solar panel: http://lightbucket.wordpress.com/2008/02/24/insolation-and-a-solar-panels-true-power-output/
For example, where I live the best I can hope for is about one tenth of the rated power during daylight hours, simply because of the combination of my latitude (around 51deg N) and weather.
For a solar powered boat you need to derate the panels to allow for the typical average daily power output through life. If you're relying on solar power to provide propulsion, then you have to size the panels to be able to generate enough power for the worst conditions - you can't work on the basis that you will get anything like the rated power, all day, every day, even if you only intend to operate at, or near, the equator.
Jeremy.
