encore8899
I've been reading and reading for the past week and can't really find solid answers for my project.
I'm sure someone has some suggestions or answers to my questions.
What I'm planning to do is build an E-trike and solar charging it. I'm planning to do some distance touring on it, maybe 50-80miles per day. I could just ride it, but I doubt I could do that many miles every day, or would want to.
In any case this is what I've narrowed it down to:
* 48V 750watt bafang bbs02 - I plan to use the most efficient minimal level of assist to maximize battery life and solar recharge, and just use more throttle uphill if needed. I could go 500watts, but I still want to have fun, or outrun a rabid dog if needed.
* 300 watts of lightweight solar panels - I want as much solar as I don't want to rely on wall charging at all, if I can help it
* Genasun MPPT 48V controller - This is only 48V I found that sells locally, which fits my application. Unfortunately it's $$. Any cheaper suggestions?
* The charge controller charges at 8amps at 48V, so 384W at peak charge theoretical.
* Trike weighs 39 lbs with a rack, and fully loaded with batteries, solar panels, solar mounting frame, charge controller should add about 15lbs. I do a lot of backpacking and know how to pack light and efficient, so maybe 80 total max.
What I have trouble deciding is the battery.
* What chemistry of battery I need? I'm leaning toward LIPO (LICO) hobbyking since it's the cheapest. But I dont really want to deal with adding a BMS. I can get the Genasun programmed to 50V so I could use a 12 s pack, which runs at 4.16V per cell. So do I need a BMS if I monitor battery discharge? Is LICO okay for charge and discharge at the same time?
* If I go Lifepo4, Genasun charge spec is 56.8V. The math says I need a 15s pack. Is that what most vendors sell? This would be more $ but less headache I think, since I can buy with BMS. I just can't wrap my head around spending $600 for a battery pack. Is this chemistry good for charge and discharge at same time?
* What size pack do I need? I'm thinking 10ah, maybe 15 for cloudy conditions.
