If you must choose heavy lead, the best bet is to look for a type rated for EV use. Not so much deep cycle, whatever that is, but constructed so that the higher discharge loads of a bike or scooter don't kill the battery so fast.
So look where batteries are sold for power wheelchairs, this will be the right type. Hundreds of types of sla's, not all best for a bike.
I consider lead still useful for bikes and scooters if,
weight will be kept low, 30 pounds the max for bikes. So 3 12v 12 ah cells, or 4 9ah. Trikes can carry more, but 50 pounds is just too much.
Distance to be traveled will be under 10 miles per charge, ideally more like 6 miles per charge. It REALLY helps lead if you only use 50% of your capacity for each ride, then charge immediately. So about 6 miles at 15 mph is the ideal.
