jimisbell
I may have been looking at a different ad when I quoted the SEER or maybe made the conversion to SEER2 in my head, but thts not important, its modern, not like my 10 yr old SEER 14
There are several videos on UTube that show how to install one. The putty is to seal up the hole in the wall where the two refrigerant pipes and control cable go thru.I may have been looking at a different ad when I quoted the SEER or maybe made the conversion to SEER2 in my head, but thts not important, its modern, not like my 10 yr old SEER 14
Seconded. And adding that my own approach is to always have a smooth mandrel (form) to bend the tube around to help avoid this.if you aree not careful they can kink and then you are in trouble
Not a quantitative answer, but look up SODIS.How much UV Light.
I question this, but don't know. I have thought of it, but not tried it.The best way is to fill it with sand (which you cant do in this case)
I'm not sure whether I should be commenting or not, but here's my understanding of how a cooling A/C unit works: the refrigerant is a substance which lends itself easily to being compressed into a liquid, and expanding into a gas. When it changes phase to a gas, it sucks energy (heat) out of the surrounding area to accomplish this. When it's compressed back into a liquid, it releases energy into the surrounding area. Household air conditioning takes advantage of this, and an A/C unit ends up being little more than a heat pump: it pumps heat out of the house and into the surrounding environment.my referral to "in this case" was about bending an air conditioner refrigerant line. Even the smallest virtually invisible grain of sand could stop an AC from working stuck in the expansion valve. I would not want to take the chance on a new air conditioner.
I am of the opposite opinion of the cold VS heat thing. Cold will kill us and is difficult to compensate for except with copious energy. But heat we can handle, just look at the Bushmen in central Africa. But solar air conditioners exist even though they are expensive. So unless the unit wears out, and it will, you have comfort. Solar heating is of course available but if the cold is severe enough...i.e Antarctic, then you are SOL.
Yes, we are working on the same problem, comfortable survival without reliance on anyone else for product or labor. IOW, can I survive in a vacuum of modern innovation.
Rock, gravel, charcoal. sand and UV in that order. If it is rain water that is all that is needed. The rocks in order of fineness Large to Small with the charcoal...no it doesnt need to be activated charcoal....before the sand so that small particles of charcoal will be filtered out of the final water is all that is needed for rainwater or AC distillate. (Rainwater IS distilled water) The charcoal filter helps with the taste, removes chemicals and odors. If you have well water or sea water you should have either RO or a still to get rid of salt or other impurities. UV light is available without infrastructure from solar powered UV lights or just put the water in a clear bottle in the open sun for 5 minutes Or simply running it thru a clear glass pipe in the sunlight. Using UV on distilled water or rainwater may not be necessary, but it wont hurt and it is easy, anyway, if you have sunshine.
A final filter of crushed limestone or, well washed, crushed, sea shells will greatly improve the taste.
Mini splits use about 1/3 less energy than conventual AC's. Seen one that runs on 48V for off grid living (HotSpot Energy DC4812VRF) over $2200. Have three Bosch installed, payed between $900 to $1500 apiece.I don't understand everything you're saying, but I meant no offense. I was just being honest and blunt; feel free to ignore my input, particularly since I was mistaken about what you were getting at to begin with. You're right, it isn't a self contradicting goal at all. The error was mine.
