I have a weller gun maybe 135 watts for soldering wire.(i don't like crimp connectors for Ag use) I use shrink tube / rubbertape. If there's a lot of amps/heat or lugs involved I'll wrap the connection with glass cloth tape to keep the mastic/rubber tape from melting into the lugs.
For small signal work and occasional soldering of 30A andersons the Weller WES-51 soldering station is great. Beyond that there are Weller 100W temperature stabilized soldering irons. Unless you need to do just few connectors I strongly advise against cheap non-regulated irons - the tip will oxidize in no time.
I'd go with something like this if you are just going to do light to intermediate soldering work. The $10-30 radio-shack or other no-name brand soldiering Irons are a waste of money, as it burns tips away and tends to warp from the heat.
A tin of solder flux is also an indispensable idem for soldiering, as it helps the solder wick where you want it to and generally make the whole process easier.
