Yes, clipless pedals are really a good thing, especially for trikes because you never need to take a foot off when you stop anyway. That may be in the cards for me.
As for power to weight, my PK Ripper BMX bike was 47 pounds AUW with pack. That bike was 8kw continuous. Now, add suspension, a touch larger frame, chromoly instead of aluminum, and a larger pack (that pack was only 8.8ah 12S) and you are probably looking at around 75 pounds for a super light E-motard. Heck, I can tell you 100 pounds is easy to achieve. After all, this trike has individual CNC battery boxes. A TIG welded single box would save alot of weight. The pack on this thing is 30ah. It weighs nearly 30 pounds by itself. Then there is the frame. That frame is quite heavy as well. So, going with a 15 AH pack, and doing everything possible to keep the weight down, I think a 60 to 65 pounds full suspension E-motard or motorcrosser is possible, but would not be easy to achieve.
Now, the CG question is a sticky one. Trikes are funky vehicles. For one thing, they require high front weight bias for stable cornering. But, the tendency to endo under braking becomes a reality as you have seen. The previous trike I built had far more weight on the front than this trike does. However, they also had brakes that are not as strong as these. As I test drove this trike, I found the front wheels skidding into corners. At the end of the video, when you hear screaching as the rear tire pitches a touch to one side, what you are hearing and seeing is not a hole or a bump, that is VERY hard braking and pitching into a turnaround at the end of that run. The inside front tire was skidding a bit. For most runs, the front tires just skid. It was a bit of a surprise that the rear end lifted at the end of the run. That happened because the front rires were hot and because I was coming to a dead stop. With any amount of corner entrance speed, it does not left the rear tire. Also, the front tires are a bit low on pressure. They will be aired up to reduce side wall roll. That will reduce endo tendency as well. Lastly, I have another 10ah of packs to add to the rear of this thing if I want to. That will add 12 pounds to the rear. But, it also adds 12 pounds to the trike and that I do not want.
Anyway, this trike is not perfect, but any means. It is a bit high powered for mere cruising. I mean, it will cruise just fine. But, it is also so powerful that care must be taken to keep from blipping the throttle too hard. The throttle is very linear, however, and that helps alot. The throttle is also somewhat long-throw. So, that makes fine throttle control a touch easier as well.
Overall I am obviously very happy. I hope it sells quickly. If not, I will add a center console, GPS, a CA, a few safety items, and new pedals. But, I am trying to turn a tidy proffit on this. So, that stuff will wait.
Matt
