Some interesting test equipment...
amberwolf
Administrator
Staff member
Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion
...found on aliexpress, that might be useful:
https://www.aliexpress.com/item/32812735435.html
there are also loads to plug into it like
https://www.aliexpress.com/item/4000897781589.html?gps-id
65w active load
multimeter unit that bluetooths to your phone to make oscilloscope (haven't read the details...just looked at the pretty pictures. ;) )
https://www.aliexpress.com/item/33034692652.html?gps-id=pcDetailCartBuyAlsoBuy&scm=1007.12908.197732.0&scm_id=1007.12908.197732.0&scm-url=1007.12908.197732.0&pvid=8d521c59-568a-47c9-a25e-8c27fe1e949d&_t=gps-id:pcDetailCartBuyAlsoBuy,scm-url:1007.12908.197732.0,pvid:8d521c59-568a-47c9-a25e-8c27fe1e949d,tpp_buckets:668%230%23131923%238_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598__668%235154%2324269%23205
I'll add more as I find them
  • 12-13-in-1-usb-tester-dc-power-meter-digital-voltmeter-voltimetro-volt-meter-power-bank.jpg_64...jpg
  • 18-in-1-USB-tester-T18-digital-voltmeter-ammeter-voltimetro-dc-power-volt-meter-Current-voltag...jpg
And some cheap deals (for probably cheap stuff) like this "temperature controlled" 80watt soldering iron, that comes with several tips, a mat, and a case...for $12.
https://www.aliexpress.com/item/32903921345.html?gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=aad6d71b-69ee-413a-a6e6-c39f28e9762e&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:aad6d71b-69ee-413a-a6e6-c39f28e9762e,tpp_buckets:668%230%23131923%2315_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598__668%235153%2324260%23205
Less than $30 shipped for a "good enough" test and soldering kit for the average DIYer.
https://www.aliexpress.com/item/4000395307932.html?gps-id=pcDetailCartBuyAlsoBuy&scm=1007.12908.197732.0&scm_id=1007.12908.197732.0&scm-url=1007.12908.197732.0&pvid=8d521c59-568a-47c9-a25e-8c27fe1e949d&_t=gps-id:pcDetailCartBuyAlsoBuy,scm-url:1007.12908.197732.0,pvid:8d521c59-568a-47c9-a25e-8c27fe1e949d,tpp_buckets:668%230%23131923%238_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598__668%235154%2324269%23205
  • Adjustable-Temperature-Electric-Soldering-Iron-kit-220V-110V-60W-Welding-Solder-Rework-Station...jpg
Lots of stuff that could be used for battery building, too...kapton tape
https://www.aliexpress.com/item/4001238923655.html?gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=e98d28fd-8231-4071-b238-34dbf4d30d1d&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:e98d28fd-8231-4071-b238-34dbf4d30d1d,tpp_buckets:668%230%23131923%2366_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598__668%235153%2324260%23205
whole-pack heatshrink
https://www.aliexpress.com/item/32877833260.html?gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=7ac2e434-880a-41d1-8b81-e4092d8c7a30&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:7ac2e434-880a-41d1-8b81-e4092d8c7a30,tpp_buckets:668%230%23131923%2394_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598__668%235153%2324260%23205
insulation / barley paper
https://www.aliexpress.com/item/32827522392.html?gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=7ac2e434-880a-41d1-8b81-e4092d8c7a30&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:7ac2e434-880a-41d1-8b81-e4092d8c7a30,tpp_buckets:668%230%23131923%2394_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598__668%235153%2324260%23205
xt60s
https://www.aliexpress.com/item/33061763696.html?gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=7ac2e434-880a-41d1-8b81-e4092d8c7a30&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:7ac2e434-880a-41d1-8b81-e4092d8c7a30,tpp_buckets:668%230%23131923%2394_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598__668%235153%2324260%23205
ultrasonic welding machine
https://www.aliexpress.com/item/1005001406978326.html?gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=e98d28fd-8231-4071-b238-34dbf4d30d1d&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:e98d28fd-8231-4071-b238-34dbf4d30d1d,tpp_buckets:668%230%23131923%2366_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598__668%235153%2324260%23205
ok...well, that's twelve thousand dollars, plus shipping, so maybe it's not sucha deal. ;) but if you need one...
assorted low-s-count bms boards
https://www.aliexpress.com/item/32887463440.html?gps-id=pcDetailLeftTopSell&scm=1007.13482.95643.0&scm_id=1007.13482.95643.0&scm-url=1007.13482.95643.0&pvid=848dd765-3c30-42b6-a2c8-b166ff254f16&_t=gps-id:pcDetailLeftTopSell,scm-url:1007.13482.95643.0,pvid:848dd765-3c30-42b6-a2c8-b166ff254f16,tpp_buckets:668%230%23131923%2394_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598_668%231000022185%231000066058%230_668%233480%2315683%23409
balancer-only boards
https://www.aliexpress.com/item/32819855859.html?gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=e25cf951-81ff-4ee9-8909-6803d38c6f65&_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:e25cf951-81ff-4ee9-8909-6803d38c6f65,tpp_buckets:668%230%23131923%238_668%23888%233325%239_668%232846%238115%232000_668%232717%237563%23598_668%231000022185%231000066058%230_668%233468%2315618%23909
assorted smart bms
https://www.aliexpress.com/wholesale?catId=0&initiative_id=AS_20210203224042&SearchText=24s+smart+bms
Interesting to compare price differential with Amazon. Also some of these are no longer available at Amazon ... https://www.amazon.com/digital-voltmeter-amperimetro-detector-indicator/dp/B07YFLSS5Q ... which has one wondering if they are still available through Ali ... https://pt.aliexpress.com/item/32812735435.html
Still looking for a reasonably priced compact dc voltage meter that reads three decimal places for Li-ion cells. I have one mini with tiny adjustable voltage trim (via Amazon) to adjust its dc voltage readout to same as my INNOVA meter. When i ordered it was given the impression that it read three decimal places, but only reads two decimal places.
What i'd like to find is an inexpensive little dc digital voltmeter that reads to three decimal places with trim for adjusting voltage readout to at least match my INNOVA meter's two decimal places.
I keep forgetting to post some pics and details of the stuff I got, so here's some pics of the USB power meter, testing it simply charging a tablet from a little wallwart. It is easy to use, and sharp enough bright display to be easy to read even though it's pretty small, at least in room lighting. Probably not so easy outside in daylight. It has alligator clip to USB adapters for both ends, so it can be used for testing ebike batteries and other things that are below it's max voltage rating of 30v, and current draw below 6.5A, or a total of 180w.
