Stotheu said:
BUT... Yesterday I did that jumper thing and bypassed terminal a and am now using terminal B and the bike is working fine and is not shutting down.! I am still not able to read the battery but the truth is this battery lasts for approximately 3 to 4 hours which is far longer than I typically ride especially when I'm with my son. This will work for now as the motor works perfectly fine but ultimately I will investigate getting a new display that can read the battery. Do you have any suggestions? I'm new to this but my understanding is that whatever new display I get would have to somehow plug into the data communicator from the title force motor which I fear the connection may be quite old. I'm really not sure?
Great job on sorting out the jumper!
That is the best solution IMO, and you can feel relieved that you weren't having a problem, the front battery was simply timing out as it is programmed to do. With the jumper installed the front battery is completely disconnected, so you can make the bike 35lbs lighter by replacing the front wheel with a regular bike wheel. Note that doing so will make the bike less balanced/sure-footed, although more agile.
You will not get the dashboard's battery meter to work with an aftermarket battery - it is controlled by the proprietary BMS (battery management system) in the front hub battery via its data cable, but that data cable was disconnected to install the jumper. The other data cable, the one from the motor, needs to stay plugged into the dashboard to get throttle signal etc but does not measure battery. However, an aftermarket meter is easy to install, and it does not use that old TF data wiring at all. Most of the people here use a product called a CycleAnalyst.
Since the battery is lasting for so long, you may not need a meter to monitor it, assuming you charge it up between rides. More data is always nice though, so if you do want a meter, I would recommend a CycleAnalyst In the CA-SA version.
Click here to see the eBikes.CA product page. This "SA" (standalone) version comes with a shunt (the part the measures volts/amps coming from the battery) that plugs into the power wires between the battery and the TF motor. You would need to install connectors on either side of the shunt that match the power plugs on your battery, and that is Everything you need to have it measure your battery usage.
If you also want to use the CA as a speedometer, it comes with a magnet the mounts on a wheel spoke, and a cable with a sensor that counts each time the magnet goes by. Installation is as simple as wire-tying the sensor to the front fork. Note that the CA is a versatile device with all sorts of extra connections you will not need on the TF, like a throttle connection coming from the shunt, and a lot of other connectors on the display, but they are optional and the CA works fine with them hanging loose.
Are you able to run the bike in Turbo mode at this point?
-JD
