notger
- Joined
- Mar 14, 2013
- Messages
- 279
hi
I just recently got tons of used makita BL1830 batteries.
My main idea was to put in new sony vtc4 cells.(what I do right now)
After rough measurements i found out that around 200 of the 300 cells are still holding voltage of around 3,9V
That's why i came up with the idea of building machine batteries or a spare ebike batterie out of the leftovers.
My plan would be:
1. Putting all the cells apart
2. sorting out all of them wich held voltage
3.charge them to 4,1-4,2 volt
4. let them sit for one week
5. measure them again
6. measure the voltage-drop on a 5A load
the next step would be really timewasting and i'm not sure if it's worth doing it?
7. testing the capacity by discharging it with a wattmeter
Any inputs to this plan?
And now my questions to you
- Wich kinds of defect on 18650 cells do you know?
- if i measure voltage on a bank (they are 5s2p batts) of 2cells can it be that one cell is still defect?
(most of the defect cells i measured have negative voltage)
- is it just possible to find out about the restcapacity and the function of the cell with a measured discharge, or is there something simpler
- Do you know of any application wich measures/tests liion cells in bulk
- Any other ideas, -> except that this is a bad idea
thanks
Gernot
My plan would be:
thanks
Gernot
