thedarlington
from CoffeeLuke: An AC.DC step down works as a DC.DC step down!!! ones with a large input ie.100V-220V will work as low as 40V.then I use $15 pc speakers.
thedarlington said:can anyone elaborate on marty's post about using switcher WALL AC Power Bricks to step down currents? im really interested in this concept but how do you connect it to the battery circuit? do you just hookup one metal wall tab to batt+ and the other to batt- ?
marty said:All your music equipment needs power usually 5V or 12V DC. No one believes that you can run most of these 120V AC adapters, off your DC bicycle battery. It does work. I tested a bunch of them with my 48V battery. They all worked. Look what Fechter figured out.
Cheap DC-DC converters for over 60v input.
USB TRAVEL CHARGER
http://www.allelectronics.com/make-a-store/item/PS-223/USB-TRAVEL-CHARGER/1.html
I don't know if this adapter will have enough amps for what you want to do? Need to ask the electricity experts that.
thedarlington said:any1 know how efficient using the wall brick to step down dc is? bc using an inverter isnt recommended for being innefficient but this is a more efficient switcher circuit that 'chops' down voltage and completely different from rel wall bricks from back in the day and inverters
