pessemist
100 µW
I have an ecoE 5k watt AWD. I essentially got swindled on the specs of this ebike. After negotiating with the seller, I kept the bike.
I tore out the fisplay, both controllers, wiring harness and replaced them with same from a Philodo Jumbo. All new.
The problem is the speedometer routinely cuts out after about two or three blocks of travel. Just drops to zero.
After sitting unpowered for awhile, the speedometer starts working normally but, again, cuts off after 2-3 blocks of riding.
Everything else works perfectly.
I’m at my wits end. The following remedies were tried which did not help:
1). Swapped in a new rear controller
2) New cable from rear controller to rear motor
3) Tried several magnet count changes in display
4) Reset Display.
5) tried another battery.
Any suggestions from the gurus here? I’m thinking maybe a display programming setting is wrong, the display is defective, or an internal motor issue?
Thanks in advance for any help.
Doug.
4) Reset Display.
Doug.
