So I'm using 2 different spoke length calculators, http://www.ebikes.ca/tools/spoke-calc.html and the Sheldon Brown spocalc http://sheldonbrown.com/rinard/spocalc.htm and they are giving me close, but different numbers. I've got the MXUS XF07 hub motor, and took my measurements off the presets on http://www.ebikes.ca/tools/spoke-calc.html. Doing 1 cross, elbow in I get 202.2mm and elbow out I get 203.2mm from that one. Using spocalc I get 203.7mm (I'm guessing elbow out?).
So, they are close, but are they close enough to say 203mm is good? Or 204mm? This is a first wheel build (prebuilt all the other times), so what would you guys suggest? I'm going to get the Sapim Strong 13ga elbow 14ga spokes. And does nipple length matter so much? 12mm? 14mm?
