The function of spokes is to provide a modicum of suspension, combined with the rim and tire. It’s a complete lightweight system that works up until the point where a good solid jolt causes the material to fail (the spoke), and it should happen long before the rim will fail and taco.
When we purchase a complete bike, moped or motorcycle, the entire system is properly weighted and calculated so that spokes and rims work flawlessly together –
short of entering into a Seattle pothole – to which there is possibly no escape! Though at least the experience is not as bad as a Florida sinkhole… just yet.
However, employing hub motors changes the equation considerably: We’re adding quite a bit more mass, and therefore adding resistance to moments of inertia which leads to greater stress upon the rim and spoke system. Spokes are the easiest to upgrade, followed by good strong rims.
If most of us rode at 20 or 25 mph, we could probably get away for a short while using the stock rim setup, but the problem is that we are either adding the motor ourselves, or purchasing an integrated motor and rim. I can guarantee that if it is the latter, the engineering has already been applied and that the rim is double-walled with good solid spokes, probably 13-gauge – at least, I’m pretty dang certain my 9C rims from
ebikes.ca are 13-gauge.
Checking their website; the
Hub Motors page states:
“I am a big guy, should I worry about spokes breaking?”
“Possibly. Crystalyte 13 gauge spokes were notorious for fatigue failing after several months of use, and this was much more prominent with heavy riders. At the time, we generally recommended that those concerned with spokes failing have their wheels re-laced either using DT, Wheelsmith, or Phil Wood spokes. These brand name spokes either in 13 or 14 gauge would work great, but unfortunately the wheel relacing and custom spoke sets added significant cost to the wheel. In late 2008 we decided to have all of our Crystalyte motors come with thick 12 gauge Crystalyte spokes. These large spokes don't generally break, but the non-standard gauge adds its own complications. The nipples won't fit through the eyelets of standard rims, replacement spokes are difficult to source, and your handy bicycle spoke wrench probably won't have a 12 gauge size for tensioning/truing the wheel.
“The Nine Continent wheels are built using regular 13 gauge Chinese spokes, and it is too early to say if they will be prone to spoke failures down the road or not. “
OK, so there you have it: Rims with hub motors are at least 13 gauge, if not 12 gauge. Using a lighter gauge with hub motors is unsafe. I can personally attest to that. :wink:
If I’m building a moped or motor-driven cycle or motorcycle, I will want to use the best spoke possible, and I won’t shy away from beefy.
The flipside of going with a very strong spoke is that the flexibility of the rim will decrease; this is when we need to employ a good frame and fork suspension system to take up for this reduction. But I think that is a good subject for another topic.
KF
