RustyKipper
Morning chaps.
Just received my new bafang cst and spokes after three weeks of chasing, unfortunately the motor arived damaged which I believe is not uncommon and the spokes I ordered seem to be of a very poor quality, there is a mix of 2.25 and 2.5mm diameter, the screw ferules seem a very loose fit and a couple don't even tighten they just pull trough, my bike takes a real pasting on my commute so no way am I risking my life with these.
I have had a search but am struggling to find many posts relating to spokes and rims, I wonder if any of you knowledgeable types have a preferred supplier, preferably here in the UK. I need 210mm for the front wheel as the 250W bafang was laced in radial fashion and the amount of spring when using the disc brake is quite alarming and I need 191mm for the rear cst, at least I believe I do from using an online spoke calculator and finding the closest size available on the BMS Battery website. The rim needs to be 36 hole 26 inch, I do have a rim with a pancake type DD motor but I want to keep that intact so I can sell it on as a complete kit when I upgrade my battery.
Many thanks for any advice.
