LewTwo
Power poster
OMG, I did it again! I have really been wanting a new Step Through Ebike with a Bafang mid drive. You may have seen my other posts considering a building CF or GF frame. I decided to not totally reinvent the wheel (or bicycle frame in this case). This is to be a city ebike …. no off-road, stair climbing or other silly things (I am an old fart with a bum left leg).
https://youtu.be/CG2cux_6Rcw
Main Components (there may seem like some odd choices):
Frame: ProdecoTech StrideMatic Low Step E-bike (*ordered*)
https://www.ebay.com/itm/124914788124
Fork: SPINNER 26" Air Suspension MTB, White (*ordered*)
https://www.ebay.com/itm/334228751390
This was used and cheap but I figure to take it apart and rebuild it (how difficult can that be?).
Rims: King-Pin 24 inch (507x34.5) , 36 spoke (*on hand*)
Tires: Schwalbe Big Apple 24x2.0 (*on hand*)
Rear Hub: Sturmey-Archer RXL-RD3, 3 Speed IGH with 90mm hub brake (*on hand*)
Front Hub: Sturmey-Archer XL-FD, 90mm hub brake (*ordered*)
OK, I know that they are slightly smaller than the frame is designed for but so what.
… and yes, I happen to like mechanical Drum brakes.
Need to order spokes and nipples .....
Battery: 52 volt x 15 Ahr, 16Sx1P Headway 40152S LiFePO4 cells (*not yet ordered*)
https://www.ebay.com/itm/203117110289
OK, I have a hangup about LFP batteries and I believe Headway makes some of the best. I figure to mount these as two sets of 8 cells. That should be a slab about 2 inches thick, 6 by 15 inches or 8 by 13.5 inches on each side of the rear wheel (I need to do same layouts). They should weight about 18 pounds with BMS and case(s).
Smaller bits and pieces:
Cane Creek A headset Zero Stack Threadless 1 1/8" Head Set (*ordered*)
Satori Con-Tec DUO UP Adjustable Stem 120mm X 31.8mm (*ordered*)
12 Volt subsystem (lights, horn, other …)
Bar end turn signals
Dual Battery Module (*possible* for spare battery)
I figure to construct some kind of bespoke rear rack (maybe from Fiber Glass) to hang the battery slabs from, mount a removable trailer hitch for my Travoy trailer. Might even extend it forward past the seat post and mount a thick half slab foam seat like mini-bike.
Any color but black: The temperatures go above 100 degrees Fahrenheit in Houston’s summer. What do you folks think about: Canary Yellow, International Orange, Livid Green or Park Blue?
Where is the best place to order a Bafang BB202 from these days?
I think that I want to gear it for a top speed of 25MPH in second gear.
What display option is the most readable in blight, glaring sunlight (Note that I abhor SmartAss phones)?
All comments, suggestions and flames are welcomed
This is kinda what the Original looked like (with my scaled dimensions).
