Hi guys,
I'd appreciate your wealth of experience on this one ...
I'm building a 13S5P li-ion ebike pack using a DIY spot welder built from a car battery (630A cold start), 500A solenoid switch, and digital timer (10ms resolution running at 80ms bursts). Having completed welding the first side of the pack with no issues, I was half way through the second half and had had a small cell puncture when the welder arc'd for some reason. Rather than have to tear the pack apart to replace the affected cell, I immediately applied some epoxy resin over the puncture hole to avoid electrolyte loss and hopefully salvage the damaged cell.
How 'catastrophic' is this cell damage to the overall pack if I continue the build without replacing the offending cell, with the epoxy 'patch' in place? Is it even possible to salvage a damaged cell with an epoxy patch? If not, what is the likely outcome of leaving the damaged cell in the pack? Will it simply die and refuse to take charge? Will it take the rest of the cells in its parallel group with it and kill them? Are there far more serious implications to be considered? Could the damaged cell go into meltdown? And affect neighbouring cells?
The ideal solution would be to tear the pack down and replace the damaged cell. But I've expended a lot of time and effort so far and tearing the pack down could easily damage other good cells. I would just like to know if there are other possible (*safe*) alternatives. Best case scenario: the epoxy patch holds and all is well. But I need to understand the likely and worst case scenarios to make a judgement as to whether that risk is worth taking.
Thoughts and recommendations?
Many thanks.
Many thanks.
