generally people that need cables like that can afford it as the machine that it powers costs many times the price of a slightly overweight extention cord.john61ct said:And 10 gauge is not even what I'd call that thick.
Put in a 60' run of 4/0 (0000, 212 kcmil) boat wire, about a half-inch cross section just for the copper.
Wire alone cost $14 a foot, nearly a grand delivered.
999zip999 said:Yea we do welding in the field and the further we get from the house or the main power source the worst the welder works and we have to bring out the big ten gauge power cable. And the outlets away from the house on the other side of the pool or by the horse stable that's far from the electrical box can have very very low power. The shorter the fatter the closer the better.
Punx0r said:If voltage drop down the mains cable is a real problem why not put some capacitors on the welder's input?
flippy said:Punx0r said:If voltage drop down the mains cable is a real problem why not put some capacitors on the welder's input?
there are caps im modern IGBT welders, but those are empty in less then a second at best.
sure, but its going to be a shitty weld.Punx0r said:Plenty long enough for a ~20 millisecond spot weld pulse then?
