Hi. Grin Tech pointed me here. Thanks if you can offer any kind of help but no worries if it's a lost cause:
Do any of you know whether those aftermarket sensors would be plug n' play with the Gen 2, or is there anything that I can do in the CYC app settings (for the BAC855) to accommodate one or the other of those?
thank you
- I have a CYC X1 Pro Gen 2 with the ASI BAC 855.
- I followed the troubleshooting guide on the CYC site and believe I have a torque sensor failure, based on seeing this in the CYC app (but tell me if you read it differently):
- The torque sensor connector shows just over 1.5v when connected and drops to close to zero when disconnected.
- Using the pas setting “axle torque” there is no reaction from the motor when turning the cranks
- Using the pas setting “single hall” there is a kind of short reaction (really just a blip or hiccup) from the motor but it's not sustained.
- The kit is on my Surly Pugsley (no kickstand unfortunately) so falls over occasionally. Given all I'm reading, I suspect that’s the cause.
- Neither CYC or the other resellers stock 100mm factory BBs for that generation. It uses a 6-pin Higo from the BB non-drive cup to connect to the controller.
thank you
