alsmith
Controller- 18 FET Lyen Edition; 36V 15Ah LiFePO4 (two)
Crystalyte 5303 front hub motor.
I'm just after a little advice /pointers please- I have a problem that seems the reverse of what you'd usually see.
I've had a problem for a couple of years where the bike doesn't properly respond to the throttle when first switched on. It did sometimes give up to full throttle but this seems to have stopped now. This didn't seem to happen for the first 6 months or so.
It gives what seems to be very little power (sometimes nothing, sometimes about 20%) when first switched on. The power slowly builds up and usually after about a mile there's full throttle available as normal.
The only thing that sometimes seems to help is unplugging the battery, then reconnecting it when it sometimes gives a bit of power, sometimes just the same as before is connecting/ reconnecting. It used to occasionally make full power available when doing this, but not now.
I hadn't asked earlier because I thought it might be related to the 45A powerpole connectors (although the controller is set to a 30A maximum) and I could hear the crack of the spark when connecting the battery and even see where arcing was affecting the contacts (36V 12Ah LiFePO4).
However I just changed all of those connectors to the physically much larger Powerpole SB50's which use the same connector as the 75Amp PP7 connector and checked all of the connections and I'm still getting the same thing- low power for the first mile or so.
I've also just fitted a new battery (36V 15Ah) and the same is happening.
I recently opened the controller to fit the wheel lock Edward Lyen gave info about and while I had the board out I had a look but couldn't see anything that looks like it's been damaged while in there.
Ed Lyen gave some things to try (disconnect CA, change throttle, disconnect 3 speed switch, disconnect cruise control) but no joy.
Any ideas?
Thanks
Any ideas?
Thanks
