Statorade in a 12" rim-integrated hub motor
TorgueRPM
Milwaukee, Wisconsin, USA
I've been looking into making an electric motorcycle for a while, and after coming across a few threads on various forums about the electric chinese grom clones (eGroms), I decided that buying and upgrading one might be my best option for now.
From what I can tell, they use these motors:
http://www.cnqsmotor.com/en/article_read/12%20inch%202000W%2072V%20Electric%20Brushless%20Dc%20In-Wheel%20Hub%20Motor%20Motorcycle%20Start%20Motor/198.html
http://g03.s.alicdn.com/kf/HTB1Fq5NX12CK1JjSZFIq6y3OpXaP/202837003/HTB1Fq5NX12CK1JjSZFIq6y3OpXaP.jpg_350x350.jpg[/img
2kW isn't going to be enough for me, so greater cooling might be needed when I push the motor to 10kW or so. I was thinking statorade, but the motors have rims integrated into them, designed to have tubeless tires directly attached, so if Statorade ferrofluid is used the usual heat transfer path might not be there.
So I have a couple of questions:
1) Will the g-forces created by a 260mm hub motor spinning at a maximum 1200rpm even allow me to use statorade in the first place?
The statorade info page says this may not be possible without a ton of ferrofluid
2) Will the tires be damaged by a potential 100C rim due to heat passing through the magnets into the shell?
You can reduce the temperature of the windings through the use of Statorade, or you can get some more power (say 60% more) out at the same winding temperature. You are not going to get 5x the power. Statorade is great, but it's not magic.
You're right about that, I guess I wasn't too clear. I'm not expecting 10kW continuous, more like 5, and even then only for hills. At 10kW continuous, my range would be terrible anyway. I'm more thinking 15kw peak, then using statorade to cool the motor down faster so I can hit 15kW peak again without waiting as long :D
Not sure about how well ferrofluid does at such high RPM. You might wanna search the forum and look into justin's ferrofluid tests.
But those motors have a lot of copper on them. It should take some abuse nicely, but 15kw is probably walking into beyond the saturation point where you get something like 2% efficiency.. might wanna shoot for 10kw peak for a bit longer to get the acceleration going.
I notice that your rim is extremely close to your magnet rings. Transfer of heat is actually a real concern. This would spook me off from pushing really high power into a wheel like that, then taking the additional step to send the heat over to the rim..
I'm not really sure what satuartion means, I'll have to look into that.
I did see this motor:
https://www.aliexpress.com/store/product/13inch-5000W-260-45H-V3-Brushless-DC-Electric-Scooter-Motorcycle-Hub-Motor/1389549_32810720886.html?spm=2114.12010612.8148356.24.16004a15s2RYq7
It has a 13" integrated rim and has a small gap between the rim and the outside of the motor. Do you think that gap would make a big enough difference in cooling? It's also rated for 5kW instead of 2kW.
Essentially saturation is when the current thru the motor is so high it is making more waste heat out of the input power than it's making rotation.
it's more complicated than that, but basically once you reach this point, you're using up power needlessly, and creating heat needlessly.
Every motor has such a point; dependent on it's design.
If you go to http://ebikes.ca/simulator you can find this point with various motor / controller setups that have been tested and modelled in it, or feed in custom parameters if you know them for a particular motor to get a guesstimate of performance.
