Stealth Bomber clone Regenerative braking
Paintpennn
Ashland OR
Are regenerative brakes possible on a stealth bomber clone with a "QS 273" motor and a sabvoton72150 controller ? Not sure what is needed or how to make that happen. Right now there is zero Regen braking.
Depends on your specific controller options.
Some just use throttle control, so if you quickly roll the throttle down from wherever it is (but not all teh way to off, it will begin braking to bring the motor speed or torque down to the level you have just set.
Some use the brake lever to engage brakingg mode, then you use the throttle to modulate the braking.
Some use the brake lever to turn on a preset single brakingg level.
Some use an analog input just for braking, and a second throttle or a brake lever with analog output to engage and modulate brakingg.
If you have the setup software for it from Siaecosys, you can connect to it via whichever method your model supports (some serial, some bluetooth, etc), and see if it has any braking options. They might not be labelled very clearly, as technical stuff is often very badly translated, often with terms that dont' actually mean anything like the function they label.
There are a few Sabvoton setup / programming threads, including some for regen/etc that may have more detailed info...just keep in mind that not every version of every model will have the same features, or the features may not work the same way as others, because companies change the firmware over time either to add things or fix problems, or because some seller or bike maker asks for specific things to be enabled or disabled or restricted, etc.
