MisterMint
Stealth City Cruiser MTB
edit: New Donor, waiting in my backyard for electrification
thumbs link to high res pictures, open in new tabs with middle click:
The story
I recently discovered that coming all sweaty to work or party is only funny for the first 2-3 hours. If you start to smell yourself its already too late..
So while I want to keep on doing conventional cycling on the weekends to loose some of ~95 Kg bodyweight - spreaded in a kinda curvy way
over my 184 cm bodyheight - I decided to buy some electrical footman for everyday A to B tasks.
Battery should last about 30-40 Km when I cycle along without getting sweaty.
fast, light, cheap, durable, comfy, secure, versatile... I want it all!!!
Surely I can´t have, at least if I keep cheap in equation.
So I go for medium affordable (< 1K€ TCO including bike), medium fast, medium light (& medium legal..hehe).
Ah yeah, don´t forget very comfy & secure. Don´t want to ruin my back and hand joints.
I also don´t want to burn down the house with cheap Lipo.
Requirements in detail:
- Light in a way that getting into trains isn´t a pita and occasional stairs will not stop me. Not like the Stock Ebikes I tried which basicly transform into real estate once empty.
- Speedwise I drive around 20-25 Km/h on even terrain without support so it should be able to get me onto 35-40 Km/h when I pedal along as I am used to (with sweating).
35 Km/h topspeed would also be fine, but I would also not cry if it can push me faster.
- According to the voices from the interwebs it should be possible to return to my home with empty batteries with up-to-date geared motors like Q100H.
It will not feel at all like the bike did before modification but it should be possible. True?
-The vehicle should be stealth or at least not cry out E-bike. Some me cheap bags in the back might support this attempt and hide the battery.
- Where I live I am often forced to drive on public streets with the traffic and people tend to get way to close to my back with their cars - even at higher speeds.
There is also alot city railway crossing streets that they still did not put underground. So plunging is simply not an option here, which is beside the sweat the most important reason
I am investing into a new secure vehicle. There is also plenty of broken glass in the city after every weekend..
- Riding up 5 cm high pavements without tipping the break and taking shorts trough the park are also nice things I can not really do with my current touringbike-frankenstein.
- And yeah, before I forget.. I need to make it (sufficiently) legal once I am tired of the full throttle.. Otherwise accidents may become very expensive.
The Plan
Reminder to myself:
It´s often a good idea to start with a simple setup to get used to matter, avoid frustration and get things into motion.
In a later stage you can still add all the fancy things your red about. Like this: http://www.speedict.com/index.jsp
So, back to the easy plan.
Platform
edit: outdated, donor is in the pictures on beginning of post.
Option 1:
http://www.ebay-kleinanzeigen.de/s-anzeige/specialized-s-works-m2-%E2%80%9Cteam%E2%80%9C/344459271-217-7530
Too expensive for what it is?
Option 2:
Trash the 26 inch - high-end MTB from the 90`s idea and find a newer 29 inch as platform.
(I just learned today that 29 inch MTB is the same rim diameter as so called 28 inch
.. they just call it 29 because the tire is thicker and it works so great to confuse newbies.)
In general I am used to 28 inch wheels and I really like the way they keep rolling straight once I reached my travel speed.
I do not mind to much about acceleration, if needed like in dangerous traffic I simply stand up and jump 2-3 times into the pedals.
(Sometimes alot weight also helps to survice.. hehe) The drawbacks of 28/29 inch are added weight of wheels and frame and also a little less
agility in ruff terrain. This is at least what the voices are telling me.
The change in wheel diameter would also change total systems reduction ratio (motor->street) to less torquey and more speedy -
which could be a good thing if the Q100H can take it without melting its tiny plastic gears. Who knows`? Seriously!
The motor and its axis would need to take more torque due to longer lever, ruffly something like factor 1.1 to 1.2 depending on tires.
Last but not least 28 inch wheels seem to have less zen, akastability in itself due to some physical reasons that I skipped.
Some reports on the net about broken spokes here.. An idea I really dislike.
Its really hard to decide here for me, as the driving characteristics of a vehicle can not really be explained in words .
The 26 inch MTB´s I have driven where fun but also kinda flimsy. Maybe this feeling changes if 500 watts are pushing in your back?
Any opinions are very welcome, just try to stay objective so we don´t end up in a wheel diameter flamewar.
Tires
edit: Tire question has been solved for now, see pics, I will buy another Big Apple 2.35 for the front as the smaller version looks really stupid.
Been lugging around the Marathon Plus on my Frankenstein for about two years and never had a single problem - heavy but durable.
Staying with the brand seems to be a good idea.
Front: Schwalbe Big Apple Plus 55-559 (26 x 2.15) GreenGuard @ 3-4 bar - 1kg (35 oz) http://tinyurl.com/q2gonv7
80% shards secure, way less dampening that the 2.35 version, not too much rolling friction
Rear: Schwalbe Big Apple 60-559 (26 x 2.35) @ 2-3 bar - 780 g (27 oz)
60% shards secure but very good dampening on low pressure. Making up a bit for the missing suspension on the rear, giving large contact area
to street so the united man & machine torque is applied to where it belongs. (Again: Acceleration is not the main focus but would make me smile.)
From what I red these two balloon tires behave very, very well on any kind of street and still acceptable on pretty much anything else beside wet mud.
(I don´t like wet mud anyways.) Guess I would not put them onto a bike without a motor as they are really too heavy for that.
Is there any experience how well the "normal" Big Apple can handle broken glass? Is there any comparable balloon style tires
around 2.35 that offer better protection? (As said, this is really an issue in my place.) And from my readings the really 2.35 offers much better
suspension then the smaller versions. Can anybody verify this? Or point me to the place where the tire fanatics live to ask them maybe?
Another option (at least for the front) would be this:
http://www.amazon.com/Schwinn-Street-Comfort-Kevlar-1-95-Inch/dp/B0088X3VL6
But I have no experience with this brand.
Motor
- Rear Q100H 36V 260 RPM @ 48 V 18-21 A http://tinyurl.com/paeqcll
If I believe the Q100H thread this motor seems to be the weapon of choice for my task,
(but I am always happy to hear I was wrong in such cases.)
Small enough to hide, will give it a matte silver paint and some fake rust spots with a toothbrush to blend better into build.
I do not expect this baby to pull me up a steep hill, I just want to cycle along as if it was (pretty) even ground.
The steepest hill I have to go up frequently is around 6%.
If this is the right choice:
- I red the new version comes with internal speed sensor and someone wrote it even had temperature sensor (which I kinda doubt).
Is any of this true? As always no info about this on BMS... god how much more would they sell if they had somebody that would condense
the info you really need into a small texts.. (and only the info, without the need to go trought lengthy, boring forums posts like mine.)
edit: new Q100H comes with speed sensor (thx motomech), still not sure about temp sensor.
- Does newer version of this motor still suffer from stuck freewheel when a fatty like me sits on top?
- Oily mess really worth the hassle (in general)? edit: NO, its not! Motor will not get to warm at 48 V, and its a real mess with the oil. (according to motomech)
Rim & Spokes
edit: outdated, will get raw motor and wide rim, friend will build it.
A friend of mine could help me to fit the raw motor with the 13G (?) spokes into a proper rim, as this would save about 60 € shipping costs I think about accepting his offer
(remember BMS does not ship directly but they must take the route via the moon..) He is a real bike nerd (with a fixation onto stripped down 26 inch pre-millenium MTB´s I guess),
and I am quite sure he will come up with some tricks that make this good thing even better.
- What rim would you recommend taking the 2.35 Big Apple at fairly low pressure and my heavy weight into account?
- What spoke lenght would match with this specific rim?
- Is it really worth the hassle or should I just get the already installed version? (This would also give me problems with proper uglyfication..)
Controller & Battery:
Remembering the reminder I gave to myself I will for now trash any fancy
ideas I will go with something like this:
https://bmsbattery.com/ebike-battery/770-48v10ah-case-02-18650-battery-pack-battery.html
Its very cheap as it comes with all external parts needed.
I wonder how they do it, are the Ah numbers on the package maybe far from reality?
edit: As Nobuo pointed out this battery would be on the low end. I will get the next bigger version,
this should improve range and battery life as well: https://bmsbattery.com/ebike-battery/765-48v116ah-case-02-panasonic-battery-pack-battery.html
Good choice? Or too much for tiny little Q100H? edit: Controller unknown itm, but seems to be a good match.
Questions regarding this specific controller (if known):
- Will it work with the Dual-hall 12 signals sensor?
https://bmsbattery.com/ebike-kit/705-dual-hall-sensor-12-signals-easy-assembling-pas-ebike-kit.html
I heard this was much more snappy..
- Is there any way without additional hardware to soft-limit it to 25 km/h? Via the LCD I guess..
Is there maybe also an easy way to temp disable this stupid 25 km/h limitation on the fly?
Maybe even something that resets on power loss? This would be great! edit: outdated question
- Will it work with throttle only connected? edit: outdated question
(Anybody tried mounting a small magnet on your thumb inside a glove.. true invisible magic this could be my friends!
Just an idea for those who suffer from limited laws like I do...
Other components in my chart (for both options):
-2 x Three Speed Switch Kit
https://bmsbattery.com/ebike-parts/53-three-speed-switch-kit-parts.html?search_query=speed+switch&results=4
Will paint it black and use this to switch lights only.. hopefully sidetracking them.. muahaha..
- HWBS - Hidden Wire Brake Sensor
https://bmsbattery.com/ebike-parts/459-hwbs-hidden-wire-brake-sensor-1pcs-parts.html
Hope I will be able to mount them to the brakes that come with the bike in a later stage.
-Torque Arms (will this protect the frame good enough even when sending 48V 17A to the motor?)
https://bmsbattery.com/ebike-parts/450-a-pair-of-ebike-torque-arm-parts.html
Is there anything missing in this list until here? (Beside the bloody spokes?)
Did I oversee something important? Any fragment of information is very welcome!
Thank you for your help!
The story
The Plan
Reminder to myself:
Platform
Option 1:
Option 2:
Tires
Motor
Rim & Spokes
