Stealth FUTR owners builds and pics
Dozie173 said:
Do you know what bottom bracket I need to fit a 53t?
The BB shouldn't really matter it's the crank spider that determines what you can fit. As mentioned I found it hard to find a larger tooth sprocket with the BCD110 spider I had.
If you are yet to build it up, I suggest looking at other BDC options that have more large sprockets available if you want to go large.
Cheers
Cheers
Adding to what CD said, the BB width is 68mm, a 53t is huge. I am not sure how much clearance between the BB and frame battery box there is. @CD, I remember you ran a big sprocket on your Alpha build, is there clearance?
You remember correctly. :)
I ran a 60T, but spaced it out with a smaller sprocket next to it.
Here's a few old photo's I managed to dig up:
Dam I miss that bike sometimes!
Cheers
So definitely a 60t not moved out past the frame's battery compartment won't clear. I am wondering if a 53T would with the chain on without being moved out. Yah CD, you had that bike built up nice and a huge battery. Was a great build.
Allex said:
Done a bit more and with wifes nail polish I had my personal final touch :mrgreen:
Need to wake up this thread a tad.
My old trusty Beta from 2015 is getting a total overhaul, we are going matte metallic pine green!
And those are titanium screws.
Swing arm bearing getting some love.
Looks great Allex!
I'm currently building a beta battery for a fellow ES member. Not the super massive split pack I previously did, but somewhere in-between at 20S7P.
Curious if you'll be doing anything different with the battery on the overhaul?
Cheers
Cowardlyduck said:
Looks great Allex!
Cheers
Mate 207P fits in perfect no need to split that's what I'm running.
Sent from my SM-N986B using Tapatalk
Yep, that's what I'm doing. Single block 20S7P.
The split pack I was referring to was the one I made a few years back that was 20S9P. Another ES member also made one first which I copied. Last I heard that pack is still going strong. :)
Cheers
Yeah I think if you look after it last while. Mine still going good after 4 years Samsung 30Q
Allex said:
The battery is as this one. My 2 yrs old 18s5p 21700 Samsung 40t
And what do you do if new forks are tapered? You make a new 1 1/8" tube for it!
As usual top notch build. How much PSI does your press have to get that tube pressed out?
Alex should work for Stealth he would be asset with his commitment and work over years.
How do find 21700? 175a be nice is 5p a squeeze.
Thx guys, I dont think I ever will sell this bike!
Here is the guy you can get cells from, 5p is perfect fit, but you can do 6p too. I just want to keep the weight down.
https://endless-sphere.com/forums/viewtopic.php?f=31&t=61608&sid=a5558666a7875befd96627e47364a1cd
Rix, dont remember how much it was, but it is a huge one but I dont think you need a beefy one to press it out.
Aand, done!
file.php
Nice as, finally someone else rocking nucular on Futr beta :)
PRW said:
Rix said:
Allex said:
Aand, done!
file.php
So beautiful!!!! Makes me want to tear my down and rebuild it.
That's a beautiful bike - me too! Luckily mine is in pieces already, waiting for a LHD Lightning Rods kit..
I was doing the LR but havnt got around to fitting up Hub to see if i can fit the LHD with gears, I will one day
Yeah, very nice Allex. You make me want to build up a Beta myself!
You won't have to wait too much longer for your battery at least....here it is about 90% complete, getting it's first charge. :)
Cheers
Cheers
It's looking good, CD! I think with this battery and Mike's motor, I will end up with a new favourite bike...
Any reason why these forks (or the USD-8's) wouldn't work for the Beta?
https://www.ebay.com.au/itm/283982955993?chn=ps&_ul=AU&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&itemid=283982955993&targetid=&device=m&mktype=pla&googleloc=1000148&poi=&campaignid=15791083372&mkgroupid=&rlsatarget=&abcId=9300816&merchantid=264054175&gclid=EAIaIQobChMIqdKS2Y6D-AIVAUkrCh2rjgwTEAQYASABEgIVgfD_BwE
Thanks
Thanks
I have these but Jay @ hyena upgraded steer tube and 20mm axle
Thanks
Thanks Cheeko - unfortunately Jay has none left!
PRW said:
Thanks
Yes it was long time ago I got them when he was still active.
@ PRW
How is the Lighting Rods Going you ended up with the 10kw Motor on the Beta i seen Lighting Post
are you doign LHD or RHD
Ill ee how you go and i think ill jump on it.
