Thanks Rick. 3.0" it is then.
I made a bit more progress over the weekend. Epoxied both upper neck area side panels in place and drilled/cutout all slots and holes for wires, and charge plugs.
The charge plug is the standard 3 pin XLR, and the balance adaptor is a parallel port breakout connector like this:
The battery will be 30AH 18S Lipo, so the plan is to hook up 3 x 6S auto balancers while bulk charging to 75V. That way it should keep the cells nicely balanced during charging without the need for a BMS.
Cheers
Cheers
